SlimsShee Posted February 16, 2013 Report Posted February 16, 2013 Custom Drag Banshee w/ (SSR) Southern Style Racing Custom Rigid Frame +4" out the front.White Knuckle built 12mil 555cc T-Rex on Alcohol made 132hp on dyno. Cylinders, Head, and Side Covers are polished. Less than 15 passes on motor.Brand New Shearer Custom Pipes for Big Bore - Chromed - Made 5hp over the CPI's on the dyno.PVL Ignition.Packard Enterprises 41mm Lectron Carbs - Can be converted to race gas if desired, just need different metering rod.2-5 Override Transmission w/ Billet 2nd Gear. Still has first gear.New Hinson Clutch Basket w/ Straight Cut Gears. Basket has the springs, not the rubber bumpers that come apart on most clutches. Also has Direct Drive Lockup.+ 12" Chrome Swingarm w/ Solid Steel Chromed Strut.Grey Fullbore Plastics front and rear, no scratches. Rear plastics not shown in picture.Brand New Wheels and Tires - 12 Paddle Staggered Skat's 22x11x8 in rear and Skat Mowhawks in front. All on new Douglas Drag Cut Wheels, Powdercoated black.Oversized Aluminum Drag Axel which has been Chromed.Custom Hubs front and rear, front are polished aluminum and rear are chromed.New wiring and hoses, including the fuel lines.Mikuni Fuel Pump due to not having oversized bowls on carbs.Brand New Biller Water Pump Impeller w/ Aluminum Cover that has easy coolant drain on it. Bearing and seals changed at same time.Custom seat from Cascade Innovations, along with other items from CI like the Brake Cover, and Throttle Cover.Brand New K&N Air Filters and Covers.New Regina DR Drag ChainNew Throttle CableNew GripsAny questions, give me a call. No Lowballers. May work on the price with the right person. Willing to trade rigid frame for +4" and up hill shooter frame.707-775-7508 or [email protected] Quote
