ICULOKN Posted January 14, 2013 Report Posted January 14, 2013 I have searched the site and read the wiring FAQ a few times. I have a drag bike I picked up that I have not tried to start but the wiring is a mess and I want to clean it up. Leaving the CDI to the Kill Switch and all is a Black, Red, Black/White, Green/Yellow. Looking through the wiring diagram It appears to me the Red & Black are normally open and get Shorted/Closed when the Factory On/Off Switch gets moved to ON? The Black/White appears to be a kill wire that should NORMALLY not See ground? Ground it out when you want to kill the bike or is that backwards? Right now the Black/White is hooked directly to the Jugs as a ground. The Red & Black are together going to the Black on the Coil and then hit a ground through a tether switch. Might be right just doesnt look right to me. Im not ready to start it yet just checking things to try and prevent as many issues as I can. Quote
EFI-shee Posted January 14, 2013 Report Posted January 14, 2013 iirc the black wire with a red tracer needs to be ungrounded all the time for spark, and the black white needs a ground however should not be tied to engine but should be soldered to the black wire. Quote
EFI-shee Posted January 14, 2013 Report Posted January 14, 2013 also if you feel like making a custom harness and run the wires it's 18 from cdi to stator and 36 from cdi to coil. no kill switch thats what the clutch is for. Quote
Starwriter Posted January 14, 2013 Report Posted January 14, 2013 iirc the black wire with a red tracer needs to be ungrounded all the time for spark, and the black white needs a ground however should not be tied to engine but should be soldered to the black wire. Welcome to BHQ. You are now the president of the 1st post fail club. The red/black wire needs to be grounded for the bike to run. The black/white wire is the kill wire and gets connected to the black ground wire to KILL the motor. Quote
ICULOKN Posted January 14, 2013 Author Report Posted January 14, 2013 Welcome to BHQ. You are now the president of the 1st post fail club. The red/black wire needs to be grounded for the bike to run. The black/white wire is the kill wire and gets connected to the black ground wire to KILL the motor. Ok so that means I can put the Red & black together and just run the Black/White through the tether and back to Ground/Black? Quote
Starwriter Posted January 14, 2013 Report Posted January 14, 2013 Red with black stripe gets connected to solid black permanently. You are correct about the tether. Quote
ICULOKN Posted January 14, 2013 Author Report Posted January 14, 2013 Pefect guys thanks! Exactly what I needed. Quote
