Ronnie Posted January 4, 2013 Report Posted January 4, 2013 Hey guys. Ok so I moved and somebody threw away my bottle of oil. I kept it so I would know what to buy. Now im back to square 1. What oil goes in the crank case I know it has to be for a wet clutch system. I don't want to smoke my new clutch. Quote
dirtydownunder Posted January 5, 2013 Report Posted January 5, 2013 if you go to a parts store and ask for a wet clutch type transmission oil, you should be fine. i use motul transoil expert 10/40 Quote
Rustynail Posted January 5, 2013 Report Posted January 5, 2013 I run ford type F transmission oil. Its cheap and widly available and never had a clutch problem Quote
20Banshee03 Posted January 5, 2013 Report Posted January 5, 2013 I also run type F transmission fluid. After some research here on Bansheehq I found a lot of people run it. Quote
Finch Posted January 5, 2013 Report Posted January 5, 2013 when ever ive used atf iv used the dex/merc one. Quote
