This might be a stupid question, but i did alot of reading about carb adjustment since i removed them and cleaned them. I have a general idea about what to do, but i cant get the stupid banshee to start in order to do any adjustments! Is there a setup i can start with and then take it from there?
Get rid of the TORS. That's always a good start. Rockymountanatv has a nice eliminator kit for around $40. Well worth the investment. Also, check to make sure the choke tube is connected. Did this thing ever run before you cleaned the carbs? Or are you trying to find the starting issue?
When I first got I used to start from first kick. After taking it to the dunes a couple of times it got worse and worse. So I decided to clean the carbs, and now it doesn't run at all. Do I start by adjusting the air and keep the fuel constant? Or is it the other way around? Or is there no specific way of doing this, just trial and error!
I would put your air screw to 1.5 turns to 2 turns out then leave them. The idle screws, I did mine by starting low, then starting it with the choke on and adjusting from there. Have you checked your plugs and compression? And have you made sure you are getting spark? Stator could have gotten dirty. Hopefully it's just something stupid to fix
