So banshee started running retarded so I started testing shit and my assumption was correct it ended up being the stator, the pick up coil ohms was barely under min required.
I also noticed my charging coil reading was like 27 or something and stock range is only like 17-20 so I figured it was a high output. Curious if anybody can identify this stator, its also got an extra wire on the harness curious what's it for.
My other concern is whether or not I should just try to buy a new pickup coil for it since another good stator is pricey as hell and hard to find or if I should buy like the moose unit or try and find a good used? Thanks 2012-12-15_19-17-43_679.jpg 2012-12-15_19-18-04_511.jpg
