So I was looking on Keihn website and from the diagram the 33 and 35mm carbs have the same dimensions.  Im wondering where the difference comes from.  I have the 33s and wonder if i should have got the 35s.  Just seems like alot more people are using them.  Thanks
  • 2 weeks later...
33S Work great on a play mtr. especially a stock stroke... If you have a 4mm stroker or are looking for more mid-top end hp then 35s will pick it up a tad.
I  see you have our porting feel free to give us a call to discuss it if you'd like..
I was thinking about going with some 28pwk's. Do the 33pwk's have good bottom end power. I have heard that with bigger carbs you loose bottom end power. Right now i am still using the stock carbs with a dune/play port.
Thanks Jeff,, I actually got everything for the motor from you but that was back in probably 2006.  Im looking to do something a little bigger.  Ill give you a call soon.  I was the Soldier that was from Frot Riley.  I know you work with alot of people.  Ill call soon  Thanks again
Sounds good! Time to make use of our Sale in my sig....  : )
