I'm looking to build a 4mil Long rod stock cylinder motor . I wanted some input on who you guys feel is best to go to for this build and what kinda setup I should go with. I mostly hit the drag strip at pismo and run hills and dumont and sandmountain and occasionaly dune a little bit but not much .
4mil 115mm rod, .030 over w/ wiseco's, Herr Juggs Drag port, Cool head w/ custom domes (132psi @ 2200ft, PUMP GAS), +2 timing, 35mm pwk's, inframe sb CPI's , VF3
Edited by Colby
nice run for a pump gas motor colby!
Is that the motor your 24x12x10 14paddles are on? haha
yep. its fine until 3rd gear, then pretty much falls on its face lol
not to bad colby. now i see my lil ol 350 aint to bad cause i got those numbers on pump gas 350. out of hjr or redline, id go redline cause thats one of the guys herrjugs calls for advise on motors
Edited by possum
