Tors or deleted? If deleted make sure your cable is all the way down in the holder and its adjusted correctly. Are the slides in the correct way with the cut out in the rear?
Are you sure you just don't have the idle turned up too high? You should think about syncing the carbs while you're at it too
no tor boxes and got no idle screws still need to get them slides are in correct way round 032kqj.jpgsorry about blury pic http://imageshack.us/a/img577/3706/032kqj.jpg
If it was me I'd pull the carbs, clean and inspect them. Bump the pilots to 27.5. Install the idle screws. Reassemble and adjust to factory specs. And start from there. Making sure the cable is properly routed, adjusted and slides are seated.
Are you trying this with the air box in place or not
yep with air box on
holy crap, if it is really 4-6c, i think that is like under 40f, and 270, is going to be lean. whenever i see pro-circuits, even though they are my favorite pipes, i must impress that you need to do a proper plug chop. in y personal experience, and tons on this site, pro-circuit pipes either go one way or the other. you should be at either 280/90, or at 320/30. anyways, there is 2 reasons that are likely for your revving. first, is an airleak. use startig fluid, or carb cleaner around the carbs and intake/cyl and listen for engine change. next, which is common, is that you are off on the mixture, and the idle is set high to compensate. if this is the case, then you will see after warming it up, and adjusting the fuel screws for the highest idle, and turning the idle back down as you do this. once you heve the highest idle, and idle turned down, turn the airscrews in 1/8 turn and it should be pretty much set, or real close.
when the 200 main jets was on it did not do this but then ak told me that should not matter carbs both lift at same time
Appearing to lift at the same time and syncd is two different things. I agreed that you are lean but until you get the idle screws its going to be hard to make the proper assessment of your problems.
ye its that cold because its half 9 and im in england also it dident do this with 200 main jets i have a pair of 290s i have not tryd would it be worth trying them out? and i do not have idle screws has they was never installed and i need to order then from usa
