KarTek Posted October 27, 2012 Report Share Posted October 27, 2012 Guys, I've read through the various threads and instructions for doing this and one thing remains unclear: The stock charging system has 2 wires coming out of the stator. When you float the ground, you add another wire to the previously grounded lug. So, now you have 3 wires. Which of the 3 do you use to connect to the reg/rec? Thanks! Quote Link to comment Share on other sites More sharing options...
Starwriter Posted October 28, 2012 Report Share Posted October 28, 2012 No, the stock charging system has 1 wire coming out of the stator. It's yellow/red on your '03. After you float the ground, you will have 2. Quote Link to comment Share on other sites More sharing options...
KarTek Posted October 28, 2012 Author Report Share Posted October 28, 2012 OK, it's not real clear when looking at the schematic. It looks like there are two wires coming off the charging side - a yellow and a black one that runs to the harness ground. Do I leave the black one as is and add the floated ground wire? Quote Link to comment Share on other sites More sharing options...
Coupelx Posted October 28, 2012 Report Share Posted October 28, 2012 Yes there is 2 wires. Electricity 101, complete circuits. Anyways the wire you add and the existing yellow wire will go to the regulator. The black wire will stay hooked up as stock. Any lights you add must be grounded back to the battery and not the frame. Quote Link to comment Share on other sites More sharing options...
KarTek Posted October 28, 2012 Author Report Share Posted October 28, 2012 OK, that makes sense, thanks! Quote Link to comment Share on other sites More sharing options...
