Tyson single a-arm chassis. Come with all chrome front suspension with Marvin Shaws & all chrome steering. Semi gloss black powdercoat prefer pickup in Oklahoma area. $1400
77-78 Rollout 14 paddle triple buff extremes on 10 inch Douglas blue labels w/metal valve stems. $475
30 inch 40mm gun drilled jj&a alum drag axle & jj&a carrier. 3 bolt pinch sprocket hub & all hardware. Could use a little polishing. $475
+10 chrome swingarm, no link setup comes with bearings, sleeve, caps & pinch bolts. $350
Complete wiring harness off drag bike, comes with cdi box, coil, stator and pro design kill switch. $125
Shearer BB inframe drag pipes, good condition but right pipe has chrome blemish. $365
Rear brake setup, master cyl, resivoir(mounting tab is broken), braided cable fit a +10 swingarm no problem(should work up to +14), billet cap, caliper and rotor. $125
Tan ostrich textured seat, brandnew cover w/latch. $150
  • 2 weeks later...
  • 3 weeks later...
