Ok. My banshee is 60 over, carbon fiber reeds, it has been ported the head has been shaved, it had the toomey t5's and the jet kit and air filter that came with the kit... it had the kit on it since it was stock and then 40 over and ported, since I had it cut to 60 and change the pipes it boges when u first hit the go fast lever and u have to pump the choke for a while to even get it to run on both side....what can I do....please help
Up the pilots one size, I'm going to assume you have stock carbs and your at 25. So go to a 27.5 Up the mains 3 sizes then do a plug chop to see where you're at. But more info would help also who did your porting?? What carbs? What pipes what's your elevation? What's the temp? But who ever ported your motor should tell you where you need to be or get you damn close.
hey thanx for the info,,,im not sure what the pilots are,,but i do know that the came with the toomey pipes and air filter kit,,,the guy i got it from said he put all toomey needles and jets from the kit but i haven checked them,,but i did check the mains and they are 270's,, ok,, my elevaitoin is 1480, fmf gold fatty's, toomey air filter w/o lid carbon fiber reeds and reed spacer adjustible timing plate set at 4+,cut 60 over and the head is cut 30,not sure of the name of the guy who done the porting but i will get his number from my bud they took them and picked them up for me,,thenx again for the help
