4 mil stroker motor, cases were bead beaded, trued and welded hot rods crank, wiseco 795 pistons (20 over),i can not get clear pictures of the pistons (need new camera), you can still see hone marks in cylinders, magnum clutch basket, tdr reeds, case saver, runs good and hard, no porting, built with a spacer head gasket, just tore it down to inspect it and reassembled with all new seals and gaskets, no stator or fly wheel, there is a crack in the upper case were the normal chain wack happens, it is not to bad (see picture) $950 plus shipping
pro design cool head with studs and o'rings, 21cc or 22cc domes, your choice $145 shipped
noss cool head anodized red, with 22cc domes and studs and new o'rings $135 shipped-------sold
brand new 21cc 4 mil stroker domes, just bought them from noss $55 shipped------sold
air box with k&n air filter and pro design adapter $65 shipped
pro curcuit pipes and silancers, left pipe has small dent $250 shipped
stock carbs with with cable $50 shipped------sold
vforce 3 reeds, like new with about 35 hours of use, come with new cascade reed stuffers $155 shipped
vforce 2 reeds, like new with about 25 hours of use, $140 shipped------sold
also have a set of cylinders with wiseco pistons, about 40 hours ride time, dune play port (i do not know who ported them, but it is a nice job and they pull hard, beat alot of 4 mil motors), the bore size 65.50 , i am tearing them off tomarrow, 152 psi with 21cc domes $225 shipped
i have some pictures now but will be posting pictures tomarrow, text 570-762-4321
