From plug chop to this.
upandgone
So did a plug chop on my quad, noticed clutch side was a little leaner than other side. I had 300 mains in, probably needs 280's? Installed timing plate at +4 and fmf sst golds.
Either way did a visual check of the carb slides and everything seemed to open at the same time and all the way so I put a synchronizer further down on my list of buying. Next was doing a leak down test, made the intake side, but parts store only had one rubber plug so its on order for tomorrow morning. Figured Id pull the clutch cover off to install my billet water pump because it has to come off anyways due to checking the seals tomorrow for leaks. Well I have a feeling I already know whats the problem is.
Suppose now would be a good time for a tare down and rebuild...banghead If I knew how easy it was to pull these apart, I would have bought the cheaper one leaking oil out the seals. I would have had to do it in the end anyways.
