bansheeboie Posted September 26, 2012 Report Posted September 26, 2012 stock carbs,fmf fatty pipes,boysen reeds,0.60 over,sea level, pd cool head,55-75 degrees air temp. any suggestions were to be at on jetting? Quote
BUILDER Posted September 26, 2012 Report Posted September 26, 2012 What is your air filter setup??? Quote
bansheeboie Posted September 26, 2012 Author Report Posted September 26, 2012 stock air box and filter Quote
Rustynail Posted September 26, 2012 Report Posted September 26, 2012 stock air box and filter 27.5 pilot- middle clip- 280 main is a good starting point Quote
BUILDER Posted September 26, 2012 Report Posted September 26, 2012 You should be right around a 260 main with a stock air box 280 is going to be pretty fat. You may need to go up on your pilot but honestly with a stock box I would stick with the stock pilot and try it and see where it is at. Quote
bansheeboie Posted September 26, 2012 Author Report Posted September 26, 2012 ok fellas il have him try this jetting with his setup and c were its at n report back. i appreciate the help Quote
