stock carbs,fmf fatty pipes,boysen reeds,0.60 over,sea level, pd cool head,55-75 degrees air temp. any suggestions were to be at on jetting?
What is your air filter setup???
You should be right around a 260 main with a stock air box 280 is going to be pretty fat. You may need to go up on your pilot but honestly with a stock box I would stick with the stock pilot and try it and see where it is at.
