  • Replies 31
  • Created
  • Last Reply
Top Posters In This Topic
Stock carbs,boost bottle,reeds,intakes.80each I have 2sets
Nerf bars-75shipped with hardware
22cc pd domes-40shipped
34mm keihin pj-180shipped with jets
Cases, no whack-170shipped
Stator covers-25shipped clutch covers-35shipped
Ct racing inframe pipes-350shipped
4mil hot rods crank(115mm) long rod-300shipped
535 redline drag ported cheetah,domes,head-325shipped obo
Toomey racing air filter-50shipped
Stock air box with pro design pro flow and other with k&n filter-70shipped each
Hot rods connecting rod for stock crank part number ck121b (nib)-50shipped
Stock shocks-45 shipped each
Stock a arm skid plate-50shipped swing arm skid plates-50shipped
Perfect stock swing arm and chain-75shipped
Complet stock clutch setups(basket,clutch,hub,pressure plate,springs)-80shipped
4mil ported cylinders w boost ports-140shipped
64mm wsm long rod pistons new(20min of run time)
Stock a arms, tie rods, hubs,spindles-110shipped
Rear brake setup, one caliper may need rebuilt other needs new pads-make offer
Front master cylinder with brake lever-50shipped
Dogbone-20shipped each
not sure who ported the dune jugs but they look good, whoever did it knew wat they were doing. intake side is very smooth. the 4mil jugs i got off a bike i bought from ct, the kid said nsx racing ported them, a local shop up there. there at 64mm. have surface rust but will come off, may need a hone/bore
