4mill HR LongRod Crank, HJR 4mill Dune/Hillshoot Port Cylinders,Cases, Case Saver, Tranny
I have a HotRods 4mill LongRod Crank (Trued&Welded) with TZ bearing on clutch side and maxload bearing on stator side in excellent condition extremely low hrs (5hrs). I have a set of Dune/Hillshoot ported by Kevin at HJR 4mill cylinders currently 64.50(.20)over bore and have several bores left. Compression upon tear down was 152psi in each cylinder, comes with Weisco 795series pistons & 23cc 4mill Domes. One cylinders has two small scars(see pic) not deep and possibly could be honed out, but I am not a machinist. Porting cost $425 alone so I believe I am throwing a hell of a deal. Bike ran strong upon tear down and fired first kick. I have a Pro-Design cool head with studs and orings in great condition. Modquad case saver in like new condition. I also have a set of engine cases that have no chain wack, one side of the cases as a spot where a stock crank rod broke in it, does not affect anything as I have used these cases on two seperate builds without no issues at all. Stock transmission in excellent condition comes with forks and rods also.
I accept paypal, please cover fees or send as a gift the packaging will be on me. PM me if you want anything.
4mill HotRods LongRod Crank w/ TZ bearing- $330 shipped
HJR Dune/Hillshoot 4mill Cylinders, Pistons, 4mill domes - $450 shipped
Case Saver - $25 shipped
Stock Tranny - $85 shipped
Engine Cases - $100 shipped
Cascade Dip Stick - $20 shipped
Pro-Design Cool Head
4mill HotRods Crank
Case Saver
Stock Tranny
HJR 4mill Dune/Hillshoot Cylinders
Scar in the one cylinder
Cascade Billet Dipstick
Engine Cases
