I got it to start now it revs high and won't idle
How high does it rev ?? If it just revs to wot then look at your carb sllides the needles or a needle might be stuck and didnt go into the carb properly holding the slide up or the slide groove might not be lined up in the carb
Pull air filter and look into the carb throats do you see both slides all the way down ? if not check needle is in center of carb properly when you installed carb top and the grove in the slide is lined up with the pin in the carb so it can go in properly
Sound like you to rich! Being to rich on the top end will sometimes cause your engine to rap out and not make any power and make the engine overheat. If it only happens at the wot its in your main jets im at 1100 and have almost the same mods and i run a 180 main and im dialed in you are much higher at 3000 with less air hope this helps.
