Ron Burgandy Posted September 10, 2012 Report Posted September 10, 2012 I've been reading the hell out of thr forums etc for about two weeks and tuning my bike recently. My bike has always ran the way it is now but I'm not sure if it's right or not? I've changed the jets and the needle positions, air screw etc. and it literally seems like it doesnt do much. No obvious air leaks etc but if I can send a video via email or text and can help that be amazing! My mods are fmf exhaust with 2into1 k&n no air box, advanced timing +5, coolhead compression 155 with pump gas 93 40:1 premix using 925. I'm also at 5000 ft elevation. Pm Me if u can help I think I may need to put new cylinders in? As far as that goes I'm not sure? That's what I'm trying to figure out. The bike runs good and has been reliable for the past 5-6 years I've had it but has always been off to me jetting wise or seems rather quiet w/ no pop. Opinions greatly appreciated. I think if I can send a video and someone can watch it to help to say what they think it is. Simple and quick is all it could be thanks Quote
SAVAGE420 Posted September 10, 2012 Report Posted September 10, 2012 Upload it too You-Tube or PhotoBucket and paste it here for all to see. While you waiting for it to upload, make a sammich. It's a win win. Quote
Ron Burgandy Posted September 10, 2012 Author Report Posted September 10, 2012 (edited) . I also have super stock Rees pedals. I had 25's with 270 mains with needle in stock positions and I changed to 290's with 30 mains and that didn't really affect the bog so I brought it back to 25's and put needle in riches position/ clip in lowest point. It's a stock needle and I don't see air leak etc. how to you think it's running?? (I just want to get rid of the bog) Edited September 10, 2012 by Ron Burgandy Quote
guns4children Posted September 10, 2012 Report Posted September 10, 2012 I can't tell from the video but maybe trim a bit off the end of your plug wires the reinstall the caps Quote
Ron Burgandy Posted September 10, 2012 Author Report Posted September 10, 2012 What does that do? Quote
shakar Posted September 10, 2012 Report Posted September 10, 2012 (edited) its jus makes sure you have a good conection, when i had that basic set up i was at 300 main 27 1/2 pilot, needle in the middle clip. but i was at 1000 ' Edited September 10, 2012 by shakar Quote
Ron Burgandy Posted September 10, 2012 Author Report Posted September 10, 2012 (edited) I'll check it out when I get off of work, so I can cut the ends shorter and re connect the spark plug caps at the end that connects to the plugs? Does it get build-up towards the caps or? Edited September 10, 2012 by Ron Burgandy Quote
Ron Burgandy Posted September 12, 2012 Author Report Posted September 12, 2012 (edited) I set my pickup gap, I used the spark plug card board thickness to set it it's real close but doesn't hit. - Here's how it runs around the neighborhood can't do much but. Edited September 12, 2012 by Ron Burgandy Quote
