LegalizeFreedom Posted September 9, 2012 Report Posted September 9, 2012 What's going on? I just got this '06 Banshee all stock with the exception of Trinity Stage 4 pipes & Trinity 2-1 filter. When I first checked it out all the lights worked as they should but after the third ride they all burnt out. I had a friend come into town & let him use it for transportation (ALL dirt roads here, legal to ride on all roads all the time), I replaced all bulbs so he wouldn't get pulled over, later that night they all burned out again & he got pulled over. Any ideas what might be going wrong? I'm about to rip this bike apart & restore it (not taken care of well) & if you guys could give me some pointers on what to look for I would greatly appreciate it. Thank you! Quote
So Cal Suspension Posted September 9, 2012 Report Posted September 9, 2012 What's going on? I just got this '06 Banshee all stock with the exception of Trinity Stage 4 pipes & Trinity 2-1 filter. When I first checked it out all the lights worked as they should but after the third ride they all burnt out. I had a friend come into town & let him use it for transportation (ALL dirt roads here, legal to ride on all roads all the time), I replaced all bulbs so he wouldn't get pulled over, later that night they all burned out again & he got pulled over. Any ideas what might be going wrong? I'm about to rip this bike apart & restore it (not taken care of well) & if you guys could give me some pointers on what to look for I would greatly appreciate it. Thank you! Sounds like you have a regulator that shit the bed. It;ll be under your seat. Silver box with a blue wire coming out of it. I'd replace that and try again. Quote
bansheesandrider Posted September 9, 2012 Report Posted September 9, 2012 Sounds like you have a regulator that shit the bed. It;ll be under your seat. Silver box with a blue wire coming out of it. I'd replace that and try again. X2, that is what mine did when the regulator went shithouse. Quote
LegalizeFreedom Posted September 9, 2012 Author Report Posted September 9, 2012 Alright then, I'll get a regulator on order. I looked them up & outside of calling Yamaha, all I can find are aftermarket regulators. Any brands I should look for/stay away from? If no ideas, I'll just call Yamaha. It'll cost quite a bit more I'm sure but buy once, cry once. Should be done right the first time, thank you both for the info! Quote
So Cal Suspension Posted September 9, 2012 Report Posted September 9, 2012 Alright then, I'll get a regulator on order. I looked them up & outside of calling Yamaha, all I can find are aftermarket regulators. Any brands I should look for/stay away from? If no ideas, I'll just call Yamaha. It'll cost quite a bit more I'm sure but buy once, cry once. Should be done right the first time, thank you both for the info! Send a pm to NYUK, or post a wanted ad. I'm sure someone probably has a bin full of them somewhere. NYUK probably has a handful of them on hand and can ship to you immediately. Quote
Starwriter Posted September 10, 2012 Report Posted September 10, 2012 Alright then, I'll get a regulator on order. I looked them up & outside of calling Yamaha, all I can find are aftermarket regulators. Any brands I should look for/stay away from? If no ideas, I'll just call Yamaha. It'll cost quite a bit more I'm sure but buy once, cry once. Should be done right the first time, thank you both for the info! Why don't you do some diagnostic work 1st? Maybe it's just unplugged. Maybe it doesn't have a good ground. Maybe there's a Billy Bob redneck wire repair in the harness that fell apart. Take the seat off and check the voltage with a multimeter at the regulator with the engine revved up. Quote
