hey guys i am just wondering the difference between a slighty lean jet at wot vs a slightly rich jet at wot because im trying to make a diagnosis.
thanks alot
I'm in for knowing how to tell for sure too.
you may jus have to bump up a jet/or raise your needle to see if its fat , if it is, then go the other way . plug chops can tell you alot. goodluck
Edited by shakar
If it's slightly rich it will struggle+not rev cleanly to peek .If slightly lean it will usually rev up quicker but be zingy+pop through the pipe.
^^^^^^^^^^^^^^ i think im running too rich then i got that with the 280, and 290's i only got one more set to try thanks alot bro cheers
