99 banshee with lots of aftermarket parts
Orange powder coated frame,gripper seat cover,yfz 450 a arms,shocks and dual piston front calipers,billet aluminum tie rods,aluminum flamed bar clamp,e brake block off, water pump cover,aluminum front bumper,rear grab bar,rear skid plate and nerf bars,DMC pipes,cascade v bar handle bars,full bore front plastics,stock rear,+2 axel with anti fade lock nut,aftermarket rear brake rotor,new brake pads front and rear,complete stainless steel bolt kit on bike,cdi relocated. Engine 70 horsepower,4 mill stroker weisco trued and welded crank,Passion Racing ported stock cylinders,cool head with pump gas domes,boss billet intake,keihn 35mm air striker carbs,billet clutch basket,modded shift star,WCR dunable 1 thru 4 tranny with manual 5th and 6th gear,15-41 gearing,double wide foot pegs with kickups,pingle dual feed petcock,nology coil and wires,billet adjustable timing plate,billet water pump impeler,V Force reeds. 3,500 OBO for 6,000 i will sell bike plus every banshee part i have,nitrous kit,pro wedge tires mounted,+2 over stock style swing are,+12 over round housing swing arm,like new kehin 35mm PWKs,3 frames 1 lightned,extra sets of plastics,gas tanks,carbs,engine cases,cranks,cylinders too much to list. 937 515 1415 Eric IMG_0001.jpgIMG_0002.jpgIMG_0004.jpgIMG_0005.jpgIMG_0006.jpg
  • 3 weeks later...
  • 2 weeks later...
what kinda port work on the cylinders and what bore ?
Not sure of the bore size,I know its not on the last bore. The porting is by Passion Racing,its his Hot MX 12 port port job.it pulls really hard mid thru top,but it still has good low end for trail riding with the air striker carbs.
