IMG_20120806_072513.jpg stage 3 elkas compression rebound adjustable valved for 225 lbs rider +2 a arms 450$ shipped
IMG_20120806_072503.jpg asv clutch lever 55$ shipped
IMG_20120806_072453.jpg front yfz master asv lever and billet cover 85$ shipped, thumb throttle with billet cover 40$ shipped
IMG_20120806_072423.jpg lock out cover and lock out, no impeller or ez drain cover thoes will be sold seperate. but 225$ shipped for lock out and cover. 250$ if you want the impeller and ez drain included
IMG_20120805_175757.jpg cpi small bore inframes 340$ shipped
IMG_20120805_152827.jpg lsr extended axle and anti fade nut is pretty beat up will include stock axle nuts also 150$ shipped
IMG_20120805_183213.jpg ac pro peg nerfs 165$ shipped with all hardware., prm front bumper 68$ shipped, prm wide grab bar 58$ shipped
IMG_20120806_072611.jpg full set of hiper carbon fiber bead locks and holeshot xc front tires and razor 2 rears 500$ for full set + shipping cost
IMG_20120805_193453.jpg some one murdered the hipers out and got happy with black spray can... what can i say ...
IMG_20120805_190027.jpg complete rear brake set up petal to line spring and clips 75$ shipped
IMG_20120801_065646.jpg modded shift star+ shift pro kit 55$ shipped
IMG_20120806_072534.jpg top notch billet head with what i believe to be 19 cc domes will post back as soon as i pull head.
my paypal is [email protected] all these prices are with gifted payments if non gifted add the paypal fees
  • Replies 69
  • Created
  • Last Reply
Top Posters In This Topic
IMAG0005.jpg dual feed pingle 55$ shipped
IMAG0003.jpg esr temp guaged 45$ shipped
IMAG0010.jpg top notch billet head 22 cc domes 125$ shipped
IMAG0008.jpg lock out cover and lock out assembly 225$ shipped
IMAG0013.jpg pods for 34/35 mm carbs mint condition fresh filters 60$ shipped
IMAG0014.jpg 34pj with power jets and filters 200$ shipped
IMAG0017.jpg yfz calipers 65$ shipped
IMAG0018.jpg yfz master asv flip lever billet resi cap and stream line extended braided lines 125$ shipped
shift pro modded star sold!
IMAG0027.jpg 65 mm cylinder unported came apart running right cylinder was at 155 left cylinder was at 150 psi so the needs pistons and rings. cylinders have no damage or scorring 215$ shipped if you want the old pistons and ring i will throw in box. no studs included thoes go with the cool head
IMAG0025.jpg billet brake line clamps 25$ shipped, thumb throttle with billet cover 40$ shipped
IMAG0020.jpg aluminum skid plate great shape 40$ shipped, also stock carrier with mint condtions bearings smooth not notchy 40$ shipped for the carrier
pingle has been sold!
