So I got a banshee a few weeks back and it came with the Trinity 2into1 carb set up. Its a 33mm carb and has a twist throttle. I got a new thumb throttleto replace it with since I'm not a fan of the twist. My question is my cable is stretched and fraying I want to replace it. Where can I find a single carb cable and what size do I need. Thanks in advance
  • 3 years later...
Thank you for your response.  I have found several threads on this topic but no real confirmation.  I hear " 250r cable will work and Blaster with TORS removed but haven't read anybody reply with a "thanks for the advise I installed the --------- cable and it worked great!".  This is my first Banshee but not my first Forum.  Drives me nuts when people don't conclude a thread.
Yes, a blaster will work, a 250r will work. A 400ex will work. Almost any single carb quad cable with work. Just needs to be long enough.
Blaster is believable, 250r is also but a 400ex or any single carb quad? Are you trying to help or hurt?  I have never seen a 4 stroke carb that takes the same small cable end barrel as a 2 stroke carb.  I just converted my brothers 440ex over to a Sudco FCR.  That cable will not work.
