thinking about parting this quad if there is enough interest then i will parts are from a 03 everything is plus shipping and paypal would be gift or you pay the fee.
motor-clean cases NO chain damage,trued and welded crank,.30 over pistons,newer clutch,shift star mod,stock head,comes with stator,flywheel,stator cover,clutch cover, NO kick starter or shifter runs and shifts great.$1000
fmf fatty pipes with power core 2 silencers,chrome is in good shape $225
35 pwk carbs with billit intakes,spacers and 35mm carb boots, velocity stacks,power jets,uni filters with outerwears and cable.$450
08 yfz 450 front shocks in good shape $225
rear shock $60
+2 a arms tops are chrome bottom grey Jb racing new tie rods and 1 set of tie rod ends, all bushings are tight $325
fatbars with adapters 2 rides on bars like new with new oury soft grips $60
durablue +2-+4 axle $200
stock steering stem $20
Rpm front bumper $35
thumb throttle $20
coil $30
cdi $50
harnes has been cut for kill switch comes with key and key switch and kill switch $75
front hubs $30
rear hubs $40
front brake calipers $30
front brake master cylinder with lever $30
complete rear brake setup $75
radiator and hoses $50
seat with new cover $75
tank $20
footpegs $20
some other parts i have laying around
billit rpm carrier needs bearing $50
64.50 mm cylinders with some port work, needs bored and there are 2 studs missing and they might need heli coiled or? havent tried putting studs in. $150
complete stock trans with shift forks and rods $100
clutch cover $25
stock reed cages with boyeson reeds $20 in ok shape can see a little gap
working lights $75
i have some other stuff ill post tomorrow and ill post pics of parts
Edited by Big B n indy
  • 1 month later...
