Big B n indy Posted July 23, 2012 Report Posted July 23, 2012 (edited) thinking about parting this quad if there is enough interest then i will parts are from a 03 everything is plus shipping and paypal would be gift or you pay the fee. motor-clean cases NO chain damage,trued and welded crank,.30 over pistons,newer clutch,shift star mod,stock head,comes with stator,flywheel,stator cover,clutch cover, NO kick starter or shifter runs and shifts great.$1000 fmf fatty pipes with power core 2 silencers,chrome is in good shape $225 35 pwk carbs with billit intakes,spacers and 35mm carb boots, velocity stacks,power jets,uni filters with outerwears and cable.$450 08 yfz 450 front shocks in good shape $225 rear shock $60 +2 a arms tops are chrome bottom grey Jb racing new tie rods and 1 set of tie rod ends, all bushings are tight $325 fatbars with adapters 2 rides on bars like new with new oury soft grips $60 durablue +2-+4 axle $200 stock steering stem $20 Rpm front bumper $35 thumb throttle $20 coil $30 cdi $50 harnes has been cut for kill switch comes with key and key switch and kill switch $75 front hubs $30 rear hubs $40 front brake calipers $30 front brake master cylinder with lever $30 complete rear brake setup $75 radiator and hoses $50 seat with new cover $75 tank $20 footpegs $20 some other parts i have laying around billit rpm carrier needs bearing $50 64.50 mm cylinders with some port work, needs bored and there are 2 studs missing and they might need heli coiled or? havent tried putting studs in. $150 complete stock trans with shift forks and rods $100 clutch cover $25 stock reed cages with boyeson reeds $20 in ok shape can see a little gap working lights $75 i have some other stuff ill post tomorrow and ill post pics of parts Edited July 23, 2012 by Big B n indy Quote
TORKER Posted August 26, 2012 Report Posted August 26, 2012 Have you decided yet? Interested on the rear brake set-up for a non computer savy friend. TORKER. Quote
kattmanntwott Posted August 26, 2012 Report Posted August 26, 2012 Will u take a bill for the cylinders Quote
