So just got the motor back from dune port. And I'm trying to sync carbs and figure out the issue. The idle is ok then I rev it it is slower to rev and I let off and it is slow to return.
4 mill fresh plugs and 25 pilot mid clip stock needle and 340 mains thanks bhq
try a 30 piolt, im guessing there stock carbs, and 1.5 turns out on the air screw
Yup got a air leak and I just tryed the 30 p and to bring down the idle the mix screws where closed and the idle was still higher but improved so I think my intake gaskets are bad.
Your still lean with a 25 pilot
But for starters do a leak down and fix that problem first!
27.5-30 pilot for sure
Ask Kevin what he recommends from experience he is usually pretty dam close with his jetting recommendations
Joe
