db25 Posted July 14, 2012 Report Posted July 14, 2012 I have a stock banshee, it only has a k&n air filter on it and I'm running 32:1on my oil mix I just recently bought a set of fmf gold series sst pipes with power core 2 silencers. I'm wanting to put them on but I need some advice on the jetting. My home area elevation is around 800ft. but I occasionally ride in 1500ft. But that's not very often. So my question is what do I need to change the jets to.? Should I run with the airbox off. what about the air to fuel screw.? Where should I turn it to.? Do I just have to change the main jet.? I don't know guys any help would be great, I don't want to take it to the shop to have it done and pay way to much.. That's for the advice Quote
db25 Posted July 15, 2012 Author Report Posted July 15, 2012 Come on guys. I know somebody can give me some help on this. Quote
Jereme6655 Posted July 16, 2012 Report Posted July 16, 2012 Read up on how to do a plug chop. Then run with some 27.5 pilots n there and around a 260-270 main (this is why you need to know how to do a plug chop to check) Quote
db25 Posted July 17, 2012 Author Report Posted July 17, 2012 I've heard about plug chops but I'm not exactly sure on them but I just want a good starting point to work with. What about the air to fuel screw..? Should I just leave it alone.? Quote
db25 Posted July 17, 2012 Author Report Posted July 17, 2012 Anybody else have any thoughts on my question. Quote
shakar Posted July 17, 2012 Report Posted July 17, 2012 Anybody else have any thoughts on my question. http://bansheehq.com/forums/index.php?showtopic=99361 <<<<read all the way through this thread, im sure lots have your same set up. also its up to you if you run a lid on the airbox, but if you dont you have to jet up. look/read around its all here good luck Quote
db25 Posted July 17, 2012 Author Report Posted July 17, 2012 1) What type of aftermarket exhaust do you have? Fmf sst gold sires with power core 2 silencers 2) What type of airfilter do you have? K&n 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all Stock airbox with lid on.. Should I take the lid off..?? 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) Roughly 800ft. 5) What size pilot jets are you using? Stock 6) What size main jets are you using? Stock 7) What temperature is your Banshee jetted for? I have no clue 8) Do you have a port job? No 9) What kind of carbs? Stock 10) What size carbs? Stock Quote
db25 Posted July 18, 2012 Author Report Posted July 18, 2012 Any other opinions on this question would be great Quote
Jereme6655 Posted July 18, 2012 Report Posted July 18, 2012 Put in 27.5 pilots. Set air screws to 1.5-2 from seated. Then put in 270 mains. Warm the bike up on the plugs that you have in it. Shut the bike down....then put brand new plugs in. Fire the bike up and immediately run the bike full throttle from 1st gear through the top of 6th.....when you get it up there pull the clutch in and shut the motor down and cost to a stop. Then reinstall your original plugs and ride home. Take a hacksaw and cut the threads off around the plug where the threads meet the base of the plug. Then you will look at the porcelain base of the plug....it should be a milk chocolate brown about the thickness of a dime. If its lighter than milk chocolate or grey then you are too lean on the mains. If it is dark brown then it is too rich. Jereme Quote
db25 Posted July 18, 2012 Author Report Posted July 18, 2012 Okay I'll give that a shot but what about the needle clip position.. What do you recommended on that.. Quote
db25 Posted July 20, 2012 Author Report Posted July 20, 2012 Needle clip position... Any advice..? Quote
db25 Posted July 22, 2012 Author Report Posted July 22, 2012 Okay I installed 270 Mains, pilot is 25, the local shop didn't have any 27.5 so I figured I would change that later. carbs are synced, needle clip is in the middle.. I'm guessing that's the stock position but idk. Bike starts great but It won't idle at all. Runs awesome other than that. when I change to the 27.5 will that fix the idle or should I change my needle position.. Any help would be great, thanks Quote
willas Posted July 30, 2012 Report Posted July 30, 2012 Okay I installed 270 Mains, pilot is 25, the local shop didn't have any 27.5 so I figured I would change that later. carbs are synced, needle clip is in the middle.. I'm guessing that's the stock position but idk. Bike starts great but It won't idle at all. Runs awesome other than that. when I change to the 27.5 will that fix the idle or should I change my needle position.. Any help would be great, thanks how do u start it? holding the throtle or ckoking it i take it. idle mostley has to do wit ur air/fuel screw, adjusting it should tune it in.. do u still have ur tors?? big headache trust me!! get rid of it or diconnect it. Quote
db25 Posted July 31, 2012 Author Report Posted July 31, 2012 Tors is removed. To start it yes I do give it a little throttle, choke if its sit awhile. The air to fuel screws are two full turns out. I messed with them some while it was running and I just couldn't get it to idle really at all, it might sputter for a couple seconds but that's it then it would die. Quote
