It's misfiring again and this time I know its not the carb. Fuel is spitting out the exhaust. Took the head off and checked the gaskets, it is a cool head. I will check the compression again tonight. Switch spark plug wires and same thing, not firing on the right cylinder. Could a crack in the cylinder wall cause this to happen?
Went to visit kim at k&t racing, had to pick up my honda 370 motor, gave me some good advise of where to start. He said first start with compression, air leak, reeds again, head, then case/crank. Kim gave me some hope and a free shirt.
Spark plug caps? coil?...Spitting fuel its either stupid rich or its not firing. But check compression first. Gas mixed with enough oxygen and a small spark and an explosion must occur so this shouldn't be to hard to fix
