gwinnraptor Posted June 17, 2012 Report Posted June 17, 2012 One carb has a gold adjustment screw (like it is setup for TORS removal) and one doesnt. Stock carbs on the bike, it was like this when i got it. Bike runs great. Is this normal? Right carb: Left carb: Quote
Buckwheat Posted June 17, 2012 Report Posted June 17, 2012 Nope. You've lost your idle screw and lock nut, unless the side without the screw hasn't been drilled and tapped . Quote
gwinnraptor Posted June 17, 2012 Author Report Posted June 17, 2012 I looked in there and its not drilled through or threaded. Its like the previous owner started the TORS removal process and then stopped. Quote
Chevy4life32 Posted June 17, 2012 Report Posted June 17, 2012 You basically answered your own question. How does it run with just one idle screw. Quote
gwinnraptor Posted June 17, 2012 Author Report Posted June 17, 2012 You basically answered your own question. How does it run with just one idle screw. Its still got the tors with the idle screw up top that adjust the idle. Runs fine. Ill be ordering the tors eliminator kit soon. Quote
