vulvafan537240 Posted June 17, 2012 Report Posted June 17, 2012 the trans version i have is not just cut gears, its a total "tuned" package.. the one i offer is also the same if not less in price than most charge for just cutting the dogs. i don't do just dog cuts either. i only sell this as a package i feel it only works in the way i have figured out. ( which took a year of research) in dirt with a lil tire slip it will shift every time and i mean if you miss a gear its going to possibly happen once in a day.. on sand with heavy hook high HP and a strong clutch with wimpy cable it may not shift 100% at high rpm's BUT its no override.. its designed for "rider bikes" proper maintenance and it will last for a very long time. i currently have these in all my "rider bikes" unless they have an override. ( i am currently working on a few override versions but its taking time because of the pickyyness of what i am trying to accomplish.) i also heavily suggest this in ANY motor that gets split. it has had great reviews and no~one has stated to me yet that they wish they didnt do it.. if you want more info please PM me. I may hit you up for this later on down the road. I've heard nothing but good reviews of yours also. Quote
sheerider11 Posted June 17, 2012 Report Posted June 17, 2012 the trans version i have is not just cut gears, its a total "tuned" package.. the one i offer is also the same if not less in price than most charge for just cutting the dogs. i don't do just dog cuts either. i only sell this as a package i feel it only works in the way i have figured out. ( which took a year of research) in dirt with a lil tire slip it will shift every time and i mean if you miss a gear its going to possibly happen once in a day.. on sand with heavy hook high HP and a strong clutch with wimpy cable it may not shift 100% at high rpm's BUT its no override.. its designed for "rider bikes" proper maintenance and it will last for a very long time. i currently have these in all my "rider bikes" unless they have an override. ( i am currently working on a few override versions but its taking time because of the pickyyness of what i am trying to accomplish.) i also heavily suggest this in ANY motor that gets split. it has had great reviews and no~one has stated to me yet that they wish they didnt do it.. if you want more info please PM me. Cam gave me a breakdown of what he does, it seems like a lot of work. Once I get my money right I'm gonna send him my trans. I also heard all good about his work. I wish I could get it out sooner. I want to bang gears WFO Quote
sheerider1026 Posted June 17, 2012 Report Posted June 17, 2012 adding a bearing to the shift drum makes a drastic improvement also.. i have cut many trannys including my own and a buddys... no issues and they shift great.. i suggest this for ANYONE that doesnt want the hassle of an overide Quote
Paulie B Posted September 26, 2012 Author Report Posted September 26, 2012 I had sheerider1026 cut my trans. The work looked great! My shee does indeed shift way better then before AND I added alot of power. FWIW I'm running a 465, your experience may be different. Power shifts for me are still unreasonalable just like they were with my modded stock stroke/stock jug bike. If your trying to trail ride/drag race a bike with power this mod will work if you let off the gas+pull the clutch all the way in then shift. If you get good at this then it's almost as fast as a dunable and you can backload the chit out of it as much as you want plus let your friends and woman ride it. My stock stroke/stoke jug bike wouldn't even do this under power at high rpms. I would consider this mod a real improvement over stock even for modded stock bikes. Quote
sheerider1026 Posted September 26, 2012 Report Posted September 26, 2012 Great to hear paulie. Thanks again Quote
