motion pro twist throttle, well no matter what i do i cant get them sync'd, i line up the lil indentations on the slide in the window on both carbs, then they open at diff times very slightly, and vise versa, line up so they open at the same time and then they dont line up in the lil windows. im thinking that the cable on one side is stretched or something. can this happen, cable is about 1.5 years old?
Edited by 01shee350
Could be one spring is wore out versus the other , swap springs and see if it swaps sides and if so get 2 new springs
there new springs, to me it seems like when the both adjusted correctly at idle one opens faster than the other at about 1/2 throttle. it doesnt make any sense, i ordered a new cable so hope that helps
