brman Posted June 3, 2012 Report Posted June 3, 2012 I have just put a Athena big bore kit on with 1/8 mile drag port on. When I'm going above half throttle the left cylinder sounds like it stops firing it kind of sounds like its a rev limit but it only does it on the left side. I have swapped the carbs, reeds, and plug wires from side to side. I also have a dyna fs cdi box. Any ideas on what is going on? Quote
brman Posted June 3, 2012 Author Report Posted June 3, 2012 I swapped the carbs from left to right and it stayed on the left side Quote
Finch Posted June 3, 2012 Report Posted June 3, 2012 stock carbs? check ohms of stator and pick up Quote
brman Posted June 3, 2012 Author Report Posted June 3, 2012 Keihn carbs. Brand new Ricky stator stator and new flywheel Quote
Finch Posted June 3, 2012 Report Posted June 3, 2012 just cuz its new doesnt mean its good. id check it ive read of them being bad right out of the box.. Quote
brman Posted June 4, 2012 Author Report Posted June 4, 2012 177 and im not sure how to check for air leaks Quote
Finch Posted June 4, 2012 Report Posted June 4, 2012 leak tester but one way to check intakes is while its running spray some carb cleaner around them and see if it revs up ( but not on your filter) Quote
brman Posted June 4, 2012 Author Report Posted June 4, 2012 It wasnt on the intake side. I'll have to get a leak tester for the cylinder side tomorrow Quote
Finch Posted June 4, 2012 Report Posted June 4, 2012 i dont know what else it could be besides cdi. i had the same prob about a month ago it was dirty prefillter but did the same thing chopped up in the higher rpms Quote
Dixie normus Posted June 4, 2012 Report Posted June 4, 2012 Gotta hate chasing gremlins. Ricky stators are very bad about breaking up in the upper rpms Quote
brman Posted June 4, 2012 Author Report Posted June 4, 2012 I got a buddy that's gonna let me try his cdi in the next day r so. I had a ricky stator last time just something came loss and messed it up so thats what i went back with it over the ebay stuff Quote
