Clymer says 2.6 qts is the coolant capacity, but I've only managed to get like 1.8 into the radiator. I've ran it a few times at idle to see if would go down but the radiator is still full. I checked the impeller when I reassembled everything and I'm 100% sure there was no coolant in it already. What do you think?
mine took less than 2 quarts on a fresh rebuild and even splashed some in the overflow bottle. same on a friends fresh rebuild last weekend. several rides later i still haven't been able to add any. i think the spec is wrong.
