jayc Posted May 13, 2012 Report Posted May 13, 2012 I swithed to a Moose racing throttle mechanism and no spark....plugged in the old throttle piece and still no spark. 10 mil cub, 40 lectrons, alky, nology coil. Quote
jayc Posted May 13, 2012 Author Report Posted May 13, 2012 Bro, you dont need 2 topics. Bro, I'm looking for a solution and didn't think people sat around and read every topic so I started a new one. My bad. I will post pics of this bitch after I blast it with a 12 ga. Quote
ClayAiken Posted May 13, 2012 Report Posted May 13, 2012 Bro, I'm looking for a solution and didn't think people sat around and read every topic so I started a new one. My bad. I will post pics of this bitch after I blast it with a 12 ga. Did you test your coil? Did you test your stator? Did you check the pickup on the flywheel? Is the Key switch on? Try new plug caps? Quote
jayc Posted May 13, 2012 Author Report Posted May 13, 2012 Did you test your coil? Did you test your stator? Did you check the pickup on the flywheel? Is the Key switch on? Try new plug caps? everything is good....went from spark to no spark just from changing the thumb throttle and carbs.......i suppose s@ happens. I will go through everything. Quote
ClayAiken Posted May 13, 2012 Report Posted May 13, 2012 everything is good....went from spark to no spark just from changing the thumb throttle and carbs.......i suppose s@ happens. I will go through everything. Double check all connections and grouds you may of knocked somthing loose. Quote
sheerider11 Posted May 13, 2012 Report Posted May 13, 2012 Do you still have the switch in the thumb throttle for the tors?? Quote
