What kind of port work are you looking for? What kind of riding do you do? Might want to specify a little more.. Just a suggestion though.
Dune port is what i I want but will consider anything just need to get my spare engine going
I got FAST Racing dune port with boost ports cylinders at 65mm bore. $ 600 with new cut pistons.
I also have a set. 65.5 mx port with wiseco pistons,wrist pins , rod bearing , cir clips, gaskets. $220 to your door.
Troy
Troy
That's a great deal. If he doesn't grab em from you I might just have to.
