007banshee Posted April 30, 2012 Report Posted April 30, 2012 When clutch lever is in all the way and rev it up bike moves a little, couple inches, doesn't lurch just rolls. There's about 1/4" slack in lever and arrows on cases are lined up. Any suggestions. Brand new clutch plates from fast, stock basket and hub. No bumps on fingers or basket. Less than 5 hours on bike. Quote
Wildcard2 Posted May 1, 2012 Report Posted May 1, 2012 Just a thought but your cable might be out and not actually engaging the clutch all the way, Quote
sheerider11 Posted May 1, 2012 Report Posted May 1, 2012 Did you change the cable? It might be stretched. The pressure plate or hub might be warped. I had this problem, but worse. I'm still in the rebuild process. I'm getting everything new. I talked to Jeff at fast and he told me something I never thought about. Some after market easy pull levers don't have enough throw or give. So it can be tricky. Quote
007banshee Posted May 1, 2012 Author Report Posted May 1, 2012 I've got a a brand new perch and lever and cable is brand new. Quote
blast off Posted May 1, 2012 Report Posted May 1, 2012 I have the same problem and also have a new cable, even a new clutch i put in a few rides back. I cant figure out the problem, very frustrating! Quote
007banshee Posted May 1, 2012 Author Report Posted May 1, 2012 I agree, wondering if i should try a new perch/lever. Bought a cheapo that's on there right now. Clutch pulled in all the way give it gas you can feel it pulse/wanna grab. Not sure if i need to adjust pancake bearing again? Any advice guys? Thanks! Quote
blast off Posted May 1, 2012 Report Posted May 1, 2012 I also have an aftermarket E/Z pull lever, but i dont know if that is it. Have you replaced the clutch lately? and if so did you use the stock springs? i did when i changed mine cuz i diddnt want a hard lever since i ride trails Quote
Banshee Bitch Basket Posted May 1, 2012 Report Posted May 1, 2012 I had a simialar issue and it ended up being the clutch pushrod Quote
007banshee Posted May 1, 2012 Author Report Posted May 1, 2012 Yea new clutch from Fast with new springs. New actuator arm,old rod and ball. New cable and lever. Only 4-5 hrs on whole engine/clutch. Quote
007banshee Posted May 1, 2012 Author Report Posted May 1, 2012 Running Belray Gear Saver for tranny fluid. Anyone else using it? Quote
blast off Posted May 1, 2012 Report Posted May 1, 2012 Running Belray Gear Saver for tranny fluid. Anyone else using it? I hear good things about belray, what weight is that? 80, 85? Belray makes good stuff. I was just saying in that other clutch post that I have some extra honda 85w gear oil and was wondering if thats ok to use or if anyone has used it. Damn, me and you are like thinking the same today lol Quote
007banshee Posted May 2, 2012 Author Report Posted May 2, 2012 Haha i guess so. I played with the adjustment at the perch and helped a little but you can still feel it move when you give it more throttle. Also i rode it around for 10min and parked it in garage, coolant was dripping from the coolant tank hose, not sure what would cause this? Its running kind fat so not sure?? Quote
007banshee Posted May 2, 2012 Author Report Posted May 2, 2012 Coolant tank wasn't full either, half empty. Quote
blast off Posted May 2, 2012 Report Posted May 2, 2012 well that usually happens when you remove the overflow tank, mine is removed so sometimes when its hot and idling a little bit will spurt out but i believe that is normal. I think the overflow tank is just a catch can, i dont think it puts the coolant back in the radiator if im not mistaken. once you start moving and get some good air flow in the radiator it should cool down the coolant and stop dripping. a billet impeller should help with that (which i plan on getting 1 day) I was also looking into an in-line temp guage. It would be nice to know what my temp is at. As for our clutch issue it might be the push rod like "banshee bitch basket" said. hahaha, that almost sounds like an insult lol. Quote
