maskmanLS6 Posted April 27, 2012 Report Posted April 27, 2012 I just put a fresh stock stroke engine together and am curiouIs as to how much power is to be gained with bigger carbs. The cylinders are ported just shy of a drag port and a bit over a trail port. Im gonna run a stock head that will be worked by Mull eng. with +4 or +5 timing and a pump and race fuel mix. Im using fmf gold series with stock carbs jetted with 30 pilots and 340 mains along with a smaller set of needles set in the middle clip. The engine runs strong and feels like its running as well as possible but i just have a feeling that there might be power to gain with bigger carbs. I think the port work will flow even more than its getting now. Quote
Coupelx Posted April 27, 2012 Report Posted April 27, 2012 theres quite a bit of difference between what most consider a trail port and most consider a drag port. Quote
S10RACER Posted April 27, 2012 Report Posted April 27, 2012 I just put 34 mm mikuni round slides on mine. Stock stroke Drag port Milled head and it made a world of difference. Quote
maskmanLS6 Posted April 27, 2012 Author Report Posted April 27, 2012 I just put 34 mm mikuni round slides on mine. Stock stroke Drag port Milled head and it made a world of difference. im probably gonna put a set on it and try it. I didnt want to spend any more money on this engine but ill always feel like i should have tried it until i do it. Quote
maskmanLS6 Posted April 27, 2012 Author Report Posted April 27, 2012 theres quite a bit of difference between what most consider a trail port and most consider a drag port. When i sent my cylinders to advanced machine I told him what kind of riding i do and he said i needed something between his drag port and trail port. Im not sure how his drag port compares to anyone elses but the work was nice and clean with even lines and amounts of material removed. I just cant help but think i need bigger carbs, its one of those things that will bug me until i try it. Quote
06specialedition Posted April 27, 2012 Report Posted April 27, 2012 What kind of riding do you do? Larger carbs you will gain some top end, but lose low if you go too big. Quote
maskmanLS6 Posted April 27, 2012 Author Report Posted April 27, 2012 What kind of riding do you do? Larger carbs you will gain some top end, but lose low if you go too big. I ride dunes and trail with a drag race here and there. I like a little of all kinds. I think bigger carbs will help some but its one of those things that make me think will it be worth the $ to do it. Quote
maskmanLS6 Posted April 27, 2012 Author Report Posted April 27, 2012 I ride dunes and trail with a drag race here and there. I like a little of all kinds. I think bigger carbs will help some but its one of those things that make me think will it be worth the $ to do it. Sand hill atv in wiggins Ms. is where i do most of my riding, its a killer place to ride and has a good mix of riding terrain. They have a web sight if your ever in the south and wanting to go for a ride. Quote
421alkybanshee Posted April 28, 2012 Report Posted April 28, 2012 im running 39mm on alcohol on my A&S drag port stock cylinders. Quote
maskmanLS6 Posted April 28, 2012 Author Report Posted April 28, 2012 im running 39mm on alcohol on my A&S drag port stock cylinders. Bad ass lookin banshee you got, Your cylinders are probably ported more than mine. Ill probably go with a set of 34mm and see what happens. Quote
