A you wont find a hub that will allow a 33 on the rear even a honda hub
B 4 teeth in the rear is 1 in the front so -8 in the rear is going up in the front +2 so basically all you are doing is leaving the rear alone and adding a tooth in the front.
mentioning not wanting SA comments only provokes ppl to make them around here.
why go smarter in the front?
if you want more top end, go 15/40
tried that and was happy with it, but with the mods i have it just seemed like there was alot more potential pull.
i know it will have the power i want with a 13, but like speeeed
well then i suggest you wish in one hand and shit in the other.
let use know which fill up faster.
Congrats dumbshit! You just made HQ prick of the day, while lurks hands are already tied around ya girls waist.
too much talk, not enough ride
gear ratio is gear ratio wheather you achieve the ratio you want with a small front/small rear or large front/larger rear combination doesn't matter for the performance. The chain will appreciate you running a larger front sprocket to achieve your desired gear ratio.
-Brandon
-Brandon
10-4
Thanks Brandon
Running stock now, looking to gain top end without killing the bottom end.
How about a 13/33? -1 in front -8 in back
Should balance out right, 1:2?
What kind of motor are you running? That is a pretty low Ratio. (Stock- 2.928 15/40 -2.857 13/33- 2.538)
A 16/41- 2.562 or a 16/40- 2.500 would get you in the same range though.
