Could anyone explain the advantage (if they has one) of the Hiper tech 3 dual bead lock over the single bead lock wheels. Why the people prefer the dual bead lock? because they are the new mode??!! or why?
The duel bead locks look better IMHO...
But as far as performance... You can literally run that rim with 0psi in the tires and not worry about the tire comming of the rim, or even slipping on the rim.
I have single beadlocks because thats what was for sale used... If I bought them new I would go with duel instead of single
An the rings are 25$ each... So instead of destroying the lip of the rim, the rings take all the abuse, 25$ and 12 screws later they look brand new
good to know!!!
can't you do the same with the single bead lock, I mean run the rim with 0psi in the tire or slipping on the rim?
Well the inside is like a normal rim... The out side where the "beadlock" is, it will clamp down on the tire rather then let the air pressure hold it there...
Changing the tire on a single beadlock still requires a tire tool and sometimes a bead breaker. Changing the tire on a dual beadlock does not require anything other than a ratchet to take the rings off.
