DirtDiggler69 Posted April 22, 2012 Report Posted April 22, 2012 Is the high beam yellow or green? 2000 Banshee if that matters . Also I have removed my key switch . It's unplugged , do I have to jumper any of the terminals? Quote
So Cal Suspension Posted April 22, 2012 Report Posted April 22, 2012 High beam is yellow, low beam is green. Also, the schematic has been posted about 480 times. Why is this in "bansheehq gear"? Quote
ClayAiken Posted April 22, 2012 Report Posted April 22, 2012 Learn how to post in the correct section. You werent even close. Quote
DirtDiggler69 Posted April 23, 2012 Author Report Posted April 23, 2012 Lol sorry my big thumbs hit the wrong section , I was wondering why I couldn't find my first post about the wiring . I primarily use my iPhone for internettin on the HQ . Quote
DirtDiggler69 Posted April 23, 2012 Author Report Posted April 23, 2012 I'll take a look at the Schematic as well . As far as the key switch , will the diagram give me any clues if just disconnecting the key switch will allow the bike to run ? I apologize for the confusion . Quote
So Cal Suspension Posted April 23, 2012 Report Posted April 23, 2012 Yes, it's a complete wiring schematic. Quote
Starwriter Posted April 23, 2012 Report Posted April 23, 2012 Do you own a multimeter? If not you need one. Check continuity of the ignition switch in the run position and that will tell you. We could tell you but you will learn a more valuable lesson by figuring this one out on your own. Quote
sheerider11 Posted April 23, 2012 Report Posted April 23, 2012 Do you own a multimeter? If not you need one. Check continuity of the ignition switch in the run position and that will tell you. We could tell you but you will learn a more valuable lesson by figuring this one out on your own. Good answer. Learn how to fix shit and why shit works one way and not the other. This way when it breaks you have an idea of what to look for. Not just jump on here and wait for the right answer to be given to you. Quote
DirtDiggler69 Posted April 30, 2012 Author Report Posted April 30, 2012 Thanks , Found it on bluetraxx!!!! See ya in the sand !!!!! Quote
