torotwister Posted April 21, 2012 Report Posted April 21, 2012 Has anyone done the older Raptor 660 rear shock with remote rezzy swap for their Banshee? If so what mod's were needed and are you happy with results? I was searching for a link with no luck, thanks for any help... Quote
decon Posted April 21, 2012 Report Posted April 21, 2012 I did this swap a while back, like you mentioned only the rear shock with the remote reservoir will work from a 2004 raptor. It's about an inch taller, no modifications needed to install it. To me it was just a quick fix, I needed a shock for my +4 swingarm and had it laying around. It worked fine for a few years until I swiched over to a stock rear shock setup/valved for my weight and swingarm. Quote
torotwister Posted April 21, 2012 Author Report Posted April 21, 2012 I did this swap a while back, like you mentioned only the rear shock with the remote reservoir will work from a 2004 raptor. It's about an inch taller, no modifications needed to install it. To me it was just a quick fix, I needed a shock for my +4 swingarm and had it laying around. It worked fine for a few years until I swiched over to a stock rear shock setup/valved for my weight and swingarm. Great, thanks a ton for your help, buddy blew his shock and we have one (660 rear) sitting around... Quote
