UPbansheeRacer Posted April 15, 2012 Report Posted April 15, 2012 i completely re did my banshee from the ground up last summer and i put all new bearings and bushings in everything and im not going into detail with everthing i did to it but the swingarm bushings are new and i havent rode the bike a whole lot since i put them in. The bushings and everything are from pivot works the swingarm bolt is tight axel bearings are good axel doesnt rock but when i step on the the bike and lean back and fourth theres some play in it Quote
brd812 Posted April 15, 2012 Report Posted April 15, 2012 i completely re did my banshee from the ground up last summer and i put all new bearings and bushings in everything and im not going into detail with everthing i did to it but the swingarm bushings are new and i havent rode the bike a whole lot since i put them in. The bushings and everything are from pivot works the swingarm bolt is tight axel bearings are good axel doesnt rock but when i step on the the bike and lean back and fourth theres some play in it What condition was your swingarm in when you installed your bearings? I had to replace my swinger cuz it was egged out from abuse and neglect on my part back when I flattracked and tt'd mine. If your bearing are sloppy on install thats were i would start. Good Luck. Quote
ClayAiken Posted April 15, 2012 Report Posted April 15, 2012 Mine moves a little. As long as its not too much run it. Quote
Larry's Shee Posted April 15, 2012 Report Posted April 15, 2012 (edited) Sure it isn't just tire squish? Support it under the engine and see if you have movement there. Edited April 15, 2012 by Larry's Shee Quote
UPbansheeRacer Posted April 18, 2012 Author Report Posted April 18, 2012 i had it jacked up its coming from swingarm im not worried about it right now ill run it but its gona be fixed before i go to silver lake this summer Quote
