dmfisher71 Posted April 6, 2012 Report Share Posted April 6, 2012 ok this may be a dumb question but i have never noticed this before, but i bought a set of 795 series wiseco piston on ebay... they are marked as 65mm (which is what i ordered)... but i measured them both, one reads 64.50 exact and the other is 64.49.... are they supposed to be like this.. my cylinders are on a wore out 64.5mm bore was going up to even 65mm... i have rebuilt many top ends on many different things but have never noticed this before.... or did i just get a "mis-stamped set of pistons"..... Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted April 6, 2012 Report Share Posted April 6, 2012 If they are 65mm pistons they should measure @64.85mm front to rear below the rings and 64.75 side to side below the rings. We have gotten Wiseco's with all kinds of different sizings and even some obvious mis-stampings in the past. If you're measuring above or at the rings you will be @64.5. Hope this helps. -Brandon Quote Link to comment Share on other sites More sharing options...
dmfisher71 Posted April 6, 2012 Author Report Share Posted April 6, 2012 ok thanks wildcard... that is where i am measuring is above the rings Quote Link to comment Share on other sites More sharing options...
