1987 250r
Nieskes
1987 250r
Hot rods 4mil crank 130.3 long rod 68mm bore 276cc
Pro designs teather
Pro Circuit pipe
.080 over 87 cylinder, decent trail port.
(I also have a spare non ported 87 cylinder on stock bore)
Fresh wiesco top end 185 psi, 14:1 Compression ratio run great on pump gas.
Hinson basket
boyesen carbon reed
Custom axis triple rate front shock, compression adj. only
Black powder coated frame
Rear custom axis shock with eibach spring, remote rez, compression and rebound adj.
Housers stock length stem/over size bar cramp
Duncan front bumper
Protaper 1 1/8 bars
Trailtech computer
Moose racing billet throttle
35mm pj carb
Piaa head lights
Durablue adj. axle
Fullbore gray plastics
chrome ims roll foot pegs
chrome ims roll shifter
chrome ims roll rear brake lever
rear anti fade lock nut
resd stainless front lines
Billet sprocket hub
lone star +2+1 aarms
Aluminum air box
Afco aluminum radiator
TM Design works chain sliders
Custom seat cover (Vegas Jeff)
Denton steering stabilizer
ITP C series rims
Maier gray gas tank cover
I also have an oversize gas tank
looking to get 3500 obo
Located in Fond du lac WI
  • Replies 38
  • Created
  • Last Reply
Top Posters In This Topic
