To start. I don't have an impact otherwise this wouldn't be an issue. I'm removing the primary drive gear nut off the clutch side of the crank but can't get it. How in the F am I supposed to get this thing off. Im too afraid to use any tools to hold the gear/crank from spinning. Any suggestions? And of course my clymer just says 'loosen the primary drive gear nut' lol. Any suggestions are appreciated
OMG don't do what these guys above said. If you are swapping cases you need to replace the crank seals, which requires the removal of the PTO gear and the nut you are talking about. Don't re-use the old case seal. You can put a piece of copper between the two drive gears to bind them in place and use the transmission/chain/rear end to hold everything in place. You can also do what the clymer manual describes and use a counter-set socket on the flywheel side of the crank and just use the crank itself to hold itself in place. As a last resort you could run down to a tire shop and ask them to use one of their impacts to bust the nut loose for you.
WRONG! Don't re-use old case seals. Horrible idea!
Ummm.. No shit. He didn't ask about replacing the seal, just if he had to loosen the nut to swap cases, replacing seals is fairly common knowledge. The question is, if you have the cases cracked open why wouldn't you replace the seals? It's just some cheap insurance. :notworthy:
Even if the seals have less than an hour on them?
Once your compress the cases on the seals you leave a groove in the seal where the cases meet. An entire seal kit is like $40. Anyone who splits cases on a regular basis should have a couple laying around. This isn't a sport for a cheap-ass. Do the shit right and use the right tools and have the right parts on-hand and ready or leave it to someone who does it the right way.
- Jared
You said above that you don't have to losen the nut to swap cases. The PTO gear sits inside the seal, which is all held on by the nut. If you are swapping cases, you should replace the seal, which would involve removing the nut to remove the water pump gear and remove the PTO gear and key, then the seal. In your first reply you say no you don't have to remove the nut to swap cases, which is WRONG. Duh. banghead
Oh no dude don't get me wrong I know exactly what you're saying, but if one were so inclined to say something like, "fuck it I'm not going to change the seal," and I'm sure those people exist, you don't in fact have to loosen that nut. I thought about mentioning the seal, I guess I should have instead of keeping it short and to the point :shootself: my bad, I should've known better.
