emtbanshee Posted March 25, 2012 Report Posted March 25, 2012 I have a .30 over banshee with fmf sst with turbine cores. I am at 639 ft above see level. What size main jets should I run? Quote
cline Posted March 27, 2012 Report Posted March 27, 2012 I have a .30 over banshee with fmf sst with turbine cores. I am at 639 ft above see level. What size main jets should I run? Just to help everybody out, should we all assume that you have stock carbs or do you have other? Also knowing your air flow situation is going to get you much better responses such as, do you have the air box complete, air box no lid, K & N's, Uni foam filters? Another factor you might want to include is current air temp you plan on jetting for. Quote
emtbanshee Posted March 28, 2012 Author Report Posted March 28, 2012 Sorry for the vague details wasn't sure what info was needed. I'm gonna run stock carbs prob with pods but at least with air box lid off. Air temp between seventy and ninety in the summer in Michigan. Quote
CFH87 Posted March 28, 2012 Report Posted March 28, 2012 What ever came out of the carbs unless you had stock pipes from the start. Quote
cline Posted March 29, 2012 Report Posted March 29, 2012 Sorry for the vague details wasn't sure what info was needed. I'm gonna run stock carbs prob with pods but at least with air box lid off. Air temp between seventy and ninety in the summer in Michigan. Its always safe to start rich and work your way down so if you are going to go with pods I would at least start with a 300 or 310. Airbox I couldn't tell ya, That was the first to go when I started riding banshees. Quote
emtbanshee Posted March 29, 2012 Author Report Posted March 29, 2012 It actually had the stock exhaust when I got it. So it still has the stock jets. Quote
notsed Posted March 29, 2012 Report Posted March 29, 2012 my buddy has 300 main 27.5 pilot middle clip, almost same set up,he has pc pipes and,he doesn't have a box and its 1or 2 main sizes big, same altitude and temp. you might want to try 280-290 with pods Quote
emtbanshee Posted March 30, 2012 Author Report Posted March 30, 2012 Thanks. I figured about 280 or 290. Already have 280 jets and just ordered 290 and 300. I'll post how it went in a few weeks. Quote
