ironmike Posted March 25, 2012 Report Posted March 25, 2012 just seeing if there any interest in my 10 mill complete bolt on and go with new crank works billet crank strait cut gears billet basket lock up billet second gear and k&t performance bearing suport case are welded and epoxyed for one of k&t performance 18 mill twister has stock ignition with adjustable timing plate mukuni 41.5 mm carbs on alcohol have jets and domes for gas text for pics 7037745825 $3800.00 cant upload pics Quote
BigRed350x Posted March 25, 2012 Report Posted March 25, 2012 just seeing if there any interest in my 10 mill complete bolt on and go with new crank works billet crank strait cut gears billet basket lock up billet second gear and k&t performance bearing suport case are welded and epoxyed for one of k&t performance 18 mill twister has stock ignition with adjustable timing plate mukuni 41.5 mm carbs on alcohol have jets and domes for gas text for pics 7037745825 $3800.00 cant upload pics You are running 10mil setup on cases that are trenched for an 18mil? That's a pretty significant case volume difference. Bump for a good deal! - Jared Quote
ironmike Posted March 25, 2012 Author Report Posted March 25, 2012 You are running 10mil setup on cases that are trenched for an 18mil? That's a pretty significant case volume difference. Bump for a good deal! - Jared sorry i didnt mean to say that the case are trenched for 10 mill but can go to 18 mill Quote
CAJUN BANSHEE Posted March 25, 2012 Report Posted March 25, 2012 Would you part from those mikunis? Quote
ironmike Posted March 25, 2012 Author Report Posted March 25, 2012 Would you part from those mikunis? no part out Quote
ironmike Posted March 29, 2012 Author Report Posted March 29, 2012 ttt ttt racing season almost here Quote
