toytech Posted March 20, 2012 Report Posted March 20, 2012 on mikuni vm round slide 34mm carbs I have to run the air screw almost closed, 1/4 turn out only, do I need a bigger pilot? if you open the air screw any more it starts hard and will not idle. thanks for any help! Quote
bansheeboie Posted March 20, 2012 Report Posted March 20, 2012 did u play w ur idle screw as well? if so and stil wnt idle its time to change pilot jet. Quote
bigboybanshee Posted March 20, 2012 Report Posted March 20, 2012 Yes, go up on your pilot jet. Closing the idle scew reduces the air making it richer. Quote
toytech Posted March 20, 2012 Author Report Posted March 20, 2012 thanks guys, thats what I thought just wanted to make sure I was thinking correctly. and yes turned the idle screws in quite a bit Quote
