Just wanted to first say awesome site i traded for a non running 2000 model and after searching post fiqured out it was the parking cable switch so big thanks.
I checked the compression and i am getting 100 and 125. Will it be ok for a few months or do i need to go ahead and take it down?
you should be ok but i would look into getting the top end done 120-130 is ideal for a stock motor
The service manual says that is rebuild time. Dl the service manual from my link. It's free.
Pull you pipes and check your pistons. Make sure no broken skirts. Do a leak down test to check for air leaks. Since to bike is new to you do a good check up and the run the hell out of it!! Enjoy
Adam
